configure ldap hierarchical-search-oid
configure ldap {domain [domain_name|all]} hierarchical-search-oid [ldap-matching-rule-in-chain | oid | none]
Description
Configures an OID to perform a hierarchical search if the LDAP server requires it.
Syntax Description
domain_name Domain name on which to configure ldap.
all All domains.
ldap-matching-rule-in-chain Configures the OID 1.2.840.113556.1.4.1941.
oid Object identifier.
none Specifies that LDAP query should not include any OID for hierarchical search.
Default
N/A.
Usage Guidelines
Use this command to configure an OID to perform a hierarchical search if the LDAP requires it. The OID supplied with this command will be used to form the LDAP query. If a server does not require extended control OID, the none option can be selected.
configure ldap domain abc.com hierarchical-search-oid ldap_matching_rule_in_chain
This command was first available in ExtremeXOS 15.3.
Platform Availability
